2/20/2024 1:23 PM | |
Joined: 5/12/2006 Last visit: 6/19/2024 Posts: 22267 Rating:
that you have use to many tags in the projekt |
3/21/2024 12:00 PM | |
Joined: 8/3/2009 Last visit: 6/20/2024 Posts: 13104 Rating:
Hello Madadi A Panel needs no license for Powertags on the Panel Runtime. But if you start simulation or PC Runtime then theoretically there is one needed. But check out this: https://support.industry.siemens.com/cs/ww/en/view/109810854 Its the same if you would have WinCC flexible Bye Murof |
