9/20/2016 8:42 AM | |
Joined: 3/30/2011 Last visit: 9/11/2024 Posts: 736 Rating: (256) |
Hello, you write in S5 conference, but if your hardware is s7-300 is better you write in SIMATIC S7 - Hardware / SIMATIC S7-300. Furthermore keep in mind that there are a lot of different S7-300 cpu and if you want some help is better to give siemens code of your cpu. You can also have all the info you need searching in the siemens support site : https://support.industry.siemens.com/cs/ww/en/ just put your cpu code in the search box (see attachment) |
9/20/2016 10:28 AM | |
Posts: 4 Rating: (0) |
sorry ! thankyou for help |
9/20/2016 10:54 AM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4767 Rating: (123) |
The second thread with the subject All fault indicator's statues on Siemens PLC is published within the SIMATIC S7-400 / S7-400H / S7-400F /FH conference. Best regards |
