6/18/2024 9:41 AM | |
Joined: 8/3/2009 Last visit: 7/15/2024 Posts: 13293 Rating: (1686)
Hello hran Yes the syntax makes no sense. you can use a nested if/then/else or you can use a switch contruct with if clauses If you want to debug your code properly then you can use also the Script debugger to see what it does: https://support.industry.siemens.com/cs/de/en/view/109779192 or use trace outputs: https://support.industry.siemens.com/cs/de/en/view/109777593 Bye Murof |
