2/19/2024 5:13 AM | |
Joined: 2/19/2024 Last visit: 2/19/2024 Posts: 1 Rating:
hi TP 1200 comfort after power supply repair but not booting kindly help reared azmat hightech ------------------------------------------------------------------------------------------ |
Last edited by: The Helping Hand at: 02/19/2024 11:12:14New subject after splitting |
2/20/2024 9:45 AM | |
Joined: 5/6/2022 Last visit: 7/24/2024 Posts: 434 Rating:
Hi azmat_ullah58, I understand that the problem you are having is that the TP1200 Comfort HMI screen does not start after sending it for power supply repair? Have you tried trying to connect to it to see if the ports respond or light up even though the screen does not turn on? If your question is more specific, can you clarify the exact problem? Best regards! |
