6/10/2014 1:18 PM | |
Joined: 5/28/2008 Last visit: 5/11/2024 Posts: 4506 Rating: (836)
Hello, In the attached pdf file, you will found the possible conecting cables that you can use for your Panel. driver should be available on your PC if you installed a WinCC flexible software or Prosave. Hope this helps.
AttachmentProjecttransfer_V1_2_e.pdf (490 Downloads) |
Ayman Elotaify |
