5/14/2010 4:48 PM | |
Posts: 12 Rating:
Is it possible to transfer a project to a TP270 panel, if it the touchscreen doesn't work? I'm working with Wincc Flexible 2007 and using a serial PPI interface. Thanks and sorry for my bad english. |
5/17/2010 8:45 AM | |
Joined: 4/29/2010 Last visit: 1/20/2025 Posts: 1557 Rating:
Hi, if you use a TP270 then you can use a USB-mouse at the USB-interface of the panel to control the panel. In this case you don`t need the touchscreen function because you can control everything with the mouse. best regards. |
