11/29/2022 11:55 AM | |
Joined: 8/3/2009 Last visit: 7/8/2024 Posts: 13244 Rating:
Hello What happens if you stop the Runtime. Do the spots also appear or only in the runtime? If the spots are there any time then I would also say there is a HW defect: https://support.industry.siemens.com/cs/ww/en/view/22639376 (I have seen a lot of damaged panels so far but no ones like this Bye Murof |
