4/29/2024 11:39 AM | |
Joined: 6/8/2022 Last visit: 8/28/2024 Posts: 1 Rating: (0) |
Sir, I'm also facing same problem . I have TIA portal v16 and HMI hardware version is TP-1500 Comfort. Hardware version TP-1500 Comfort v2 therefore i am not able to communicate with TIA portal sol= please guide us to get the solution. I have attached both pic for your references. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 04/30/2024 06:08:09New subject after splitting |
5/8/2024 11:59 AM | |
Joined: 8/3/2009 Last visit: 10/31/2024 Posts: 14079 Rating: (1765)
Hello 7518 Check the basic for a HMI transfer: https://support.industry.siemens.com/cs/ww/en/view/58522603 If this do not work send us a few more Information and Screenshots which Errors do you get Bye Murof |
