10/5/2020 10:39 AM | |
Joined: 8/3/2009 Last visit: 5/27/2024 Posts: 12984 Rating: (1653)
Hello with wich Tool do you work? WinCC flexible or Protool? If you have installed the Engineering SW then also the PAnel images are installed. You can find them in Installation path. To do a reset to factory settings you need: https://support.industry.siemens.com/cs/ww/en/view/19701610 -> Please look which Cable you need in this Manual. Bye Murof |
