8/10/2022 1:52 PM | |
Joined: 5/30/2022 Last visit: 8/6/2024 Posts: 559 Rating:
Hi pankaj_054, Thinking about your problem, I have the following doubts: 1- Are you using the original Siemens PC Adapter? 2- Have you been able to install the drivers? If not, I attach a link: https://support.industry.siemens.com/cs/ww/en/view/78453460 Can you be more specific about the problem you are having?
If this information really helps, you could use the Rate function. |
