9/21/2022 12:54 PM | |
Joined: 8/3/2009 Last visit: 9/11/2024 Posts: 13647 Rating:
Hello Sundance00 This is NOT correct! you can only perform a Reset to factory settings with a TP177B 6" PN/DP with: - RS/232 PPI-MM cable 6ES7 901-3CB30-0XA0 - USB PPI MM calbe 6ES7 901-3DB30-0XA0 -->> No other cable will work (the other options in Prosave are only for a common OS Update or Backup/Restore but not for a Factory Reset!) https://support.industry.siemens.com/cs/ww/en/view/19701610 Bye Murof |
