5/19/2020 6:55 PM | |
Joined: 2/5/2013 Last visit: 9/5/2024 Posts: 321 Rating:
May be below links will be helpful to you. Image downloads for HMI operator panels Br, |
Last edited by: Jen_Moderator at: 05/20/2020 09:07:48Optimized links. Please rate it. |
2 thankful Users |
5/20/2020 10:47 AM | |
Posts: 21 Rating:
Actually I could not locate the appropriate image file for TP700 comfort screen because there is no direct file name! |
5/20/2020 11:14 AM | |
Hi ABDO_2011 I assume that you have 1.Checked all links provided in previous posts. 2.You have installed respective image Currently i don't have image install image for TP700 but I will show demo picture for KTP 1200 1.Select Particular HMI in your case it is TP 700 2. Select File with V1X_00_01_00.fwf These files generally located on C:\Program Files (x86)\Siemens\Automation\Portal V13\Data\Hmi\Transfer\13.0.1\Images as I have TIA 13 installed on my PC May be it will solve your issue. Br, AmolG |
