2/14/2019 3:02 PM | |
Joined: 4/24/2006 Last visit: 11/15/2024 Posts: 8768 Rating: (1171)
Hello, I'm afraid you will have to send them in for Repair. Best regards, Wizard |
2/14/2019 5:19 PM | |
Joined: 9/3/2008 Last visit: 11/14/2024 Posts: 928 Rating: (163) |
Hi, This is an issue that can happen. You need to reset it booting on a usb: How do you do an operating system update on operator panels or perform a "Reset to factory settings"? The usb need to be usb 2.0 and even then, not all usb sticks work, so you may need to search around. |
Michael |
2/16/2019 9:43 AM | |
Joined: 9/10/2011 Last visit: 10/16/2023 Posts: 37 Rating: (2) |
Thank you for your advices this is for ktp panels. in prosave document: https://support.industry.siemens.com/cs/attachments/19701610/19701610_prosave_1_2_e.pdf based on Table 2-1,only PN/ethernet and PtP cross can be used for os update. also i want to know what causes this problem and how can prevent ? |
2/17/2019 8:18 PM | |
Joined: 4/21/2015 Last visit: 11/17/2024 Posts: 56 Rating: (2) |
Unfortunately, you can not do it because it requires technical repairs
