7/6/2020 4:20 PM | |
Joined: 2/5/2014 Last visit: 9/28/2024 Posts: 2 Rating: (1) |
Hello all, Could you help me. I have TP900 Comfort and KTP400 in one project. With TP900 I´m not able to change date and time format. I need standard middle European. So I have changed in System text h.m.ss.tt to H:mm:ss and M/d/yyyy to d.M.yyyy. KTP400 is working but TP900 has still the same format US. I have simmilar applications where working without problem with this setting. Not possible to find Alarm text 330018 and 330019. many thanks for help Jiri Koren ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 07/07/2020 06:06:22New subject after splitting |
7/7/2020 8:36 AM | |
Joined: 5/6/2017 Last visit: 9/12/2024 Posts: 10 Rating: (1) |
Hello Jiri Koren, You can change date and time format in TP900 Comfort as follows;
If this information helps you, then you can use the rate function. |
