9/12/2022 12:16 PM | |
Joined: 8/3/2009 Last visit: 9/11/2024 Posts: 13647 Rating:
Hello AutomativePolska1... If the Panels do not start and want to have a Reset to factory settings then you can do so: https://support.industry.siemens.com/cs/ww/en/view/19701610 After then panel works again properly you can try again the restore (perhaps something went wrong in first attampt) Bye Murof |
