5/23/2022 3:18 PM | |
Joined: 2/6/2019 Last visit: 9/30/2022 Posts: 5 Rating:
Hello everyone, I want to transfer Data logging, Audit logging, alarm logging CSV file from HMI local storage to Clients centralized PC. I have TP700 comfort panel. All the setting which i did , I attached in Attachment. after that setting HMI not able to find the PC folder path to save file. what setting i am missing please suggest me. following document i reffered: 1. 92346478_TCP_IP_Networks_Panel_DOC_v2.0.en 2.92346478_WinCC_TIA_Archiving_ServerNAS_DOC_v2.0_en Attachmentsettings.pdf (579 Downloads) |
7/4/2024 7:41 AM | |
Joined: 6/26/2024 Last visit: 7/11/2024 Posts: 1 Rating:
Is you problem solved????if yes can you tell me how you are solved it pls |
