2/23/2013 11:26 AM | |
Joined: 12/22/2006 Last visit: 1/25/2022 Posts: 1742 Rating: (309) |
Hello, Be aware that in the S5-100 family of CPUs, the CPU102 is a CPU that can work in two modes: - test mode - normal mode Test mode -You can enter, modify, or erase PBs, OBs and FBs only in the test mode. - You can read out the STEP 5 program with the programmer. - Program processing is faster in the normal mode, but you can not use the STATUS test function. |
Best regards |
