8/20/2015 10:02 PM | |
Posts: 111 Rating: (1) |
I am having a trouble in archiving a program as I retrieved the program make some changes in the program and now I am trying to archive it again but its go to bottom page and stuck and also creating a archieved file but if I am trying to retrieve newly created file then it is giving me below mentioned error. Can anybody help....
------------------------------------------------------------------------------------------ AttachmentPictures.zip (125 Downloads) |
Last edited by: Min_Moderator at: 8/21/2015 11:23:44 AMNew subject after splitting |
8/21/2015 11:52 AM | |
Joined: 1/28/2009 Last visit: 10/26/2024 Posts: 6852 Rating: (1365)
Hello Shahjee, Error 3020:54 means, you retrieved a project that is not recognized as standard S7 project (e.g lack of .s7p file in project).As we are not aware of your source project your are testing, open one of standard sample projects in STEP 7 that can be accesses with File-->Open-->Samples.Try to archive and restore it .If no problem at this stage, Retrieve your original file-->Apply changes-->Save it in a new place "with reorgnize slow"-->archive and then retrieve.If you still have problem, check remedies discussed in the following FAQ: What remedies are available when it is not possible to archive or retrieve STEP 7 projects?
I hope this helps, hdhosseini |
