10/25/2012 11:12 AM | |
Joined: 4/24/2006 Last visit: 12/20/2024 Posts: 8786 Rating: (1172)
Hello tmcolby, What version of WinCC (TIA Portal) are you using? I guess you already have seen this link: how can you have any number of automation systems addressed one after the other by the "Change Connection" function with WinCC flexible PC Runtime or a Panel? Use some internal tags to help Best regards, Wizard |
4/11/2014 10:29 AM | |
Joined: 5/25/2012 Last visit: 12/7/2023 Posts: 16 Rating: (2) |
there is also a script function you can use: ChangeConnection "Connection_1", "YOUR_IP", 1, 0 |
