7/18/2023 7:59 AM | |
Joined: 12/16/2012 Last visit: 7/23/2024 Posts: 653 Rating:
Hi! I did not use this but you could try to do xml compare: Exporting blocks Now, if you need to compare the data structure of a DB with another DB from the given specs, it would be more elegant to use and compare typified PLC data types instead of DBs. |
Last edited by: Kahl at: 07/18/2023 08:03:48Last edited by: Kahl at: 07/18/2023 08:07:27second link added |
