1/22/2018 2:43 PM | |
Posts: 6 Rating: (1) |
hi, im trying to reference Z axis on a 5axis machine that we removed the Z axis column. the Z axis has a heidnmann linear scale , ive tried alot of different parameters , ive tried "human" comment when ever i press Ref after changing the parameters and adding that value position , the z axis only moves 20 mm in either direction im pressing if i press the ref - then + it will move + direction for bout 20mm then say its referenced. but i press it again and it does same thing changing the reference all the time, even if i press "-" it will move "-" and reference there aswell. any ideas ? ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 1/23/2018 9:08:20 AMNew subject after splitting |
1/27/2018 6:43 AM | |
Joined: 10/17/2007 Last visit: 7/14/2024 Posts: 4008 Rating: (353)
Hi, peeka, you need tell forum why you need make Z axis ref. you change motor of Z ax? or some reason? and PISCEAN answered your question. you need read Siemens manual--looking for DocOn WEB--840D power line? (you did not say?)---FB1 (function description part1) R1--Reference --find steps in chapter--for "Distance-coded linear scale " reference sequence. check all related NC MD PS: for manual search by Google 11/2003 edition---download it SINUMERIK 840D/840Di/ SINUMERIK 810D Description of Functions Basic Machine (Part 1)
Last edited by: nulizhang at: 1/27/2018 6:48:38 AMyou need read book Last edited by: nulizhang at: 1/27/2018 6:57:25 AMYou can read this part of book--see attached pic If you like my comments please |
