11/28/2012 8:17 PM | |
Posts: 62 Rating: (0) |
Dear Darius, I am also trying web navigator frst time, i am using wincc7+sp3. i followed web navigator server steps in one laptop and published my pages. now i used wincc viewer rt in my another pc.i used server name as IP adress which given in web navigator server setting. both my lap & PC having wireless internet connection...i am not able to acheive the connection. plz guide find the attachement for your understanding Thanks krk Attachmentwebnavigator.zip (218 Downloads) |
Last edited by: O_Moderator at: 11/29/2012 12:09 PMnew subject after splitting from /tf/WW/en/Posts/75027#top Last edited by: KRK_1986 at: 11/29/2012 9:23 AM |
11/29/2012 2:16 PM | |
Hi Experts , how to check the connection? |
11/29/2012 3:53 PM | |
Joined: 4/14/2010 Last visit: 8/6/2024 Posts: 525 Rating: (11) |
DearKRK_1986, Connect your both PC with wireless router Via Ethernet (cable) TCP/IP RJ45 port then try again.
MS |
12/3/2012 8:13 AM | |
Dear KRK_1986, could you send me snapshot for internet setting..?? |
MS |
12/3/2012 9:59 AM | |
Hi sarfraz, sorry, actually what are the setting required to publish my webpage in internet? Thanks krk |
12/7/2012 10:51 AM | |
Dear KRK_1986, you configure the WebNavigator Server with the WinCC WebConfigurator. After that the WebSite is available in the IIS and you are able to connect via Internet. If you configure a special IP you can access the WebServer only via http://ipadress if you use "all not assigned" in the webconfiguratoryouwill beable to access the webnavigator webpagevia http://webservername for further information see this link https://support.automation.siemens.com/WW/llisapi.dll?func=cslib.csinfo&lang=en&siteid=cseus&aktprim=0&extranet=standard&viewreg=WW&objid=10805593&treeLang=en |
12/7/2012 2:09 PM | |
Posts: 1 Rating: (0) |
hi, your wincc don't have the available key, it is in the demo mode |
12/8/2012 11:27 AM | |
Hisarfraz, Thanks for your suggestion, i wll read that manual and let you inform the result. thanks krk
