12/16/2020 1:09 PM | |
Joined: 3/14/2020 Last visit: 6/2/2024 Posts: 3 Rating: (0) |
Hello I am going to turn on my pc by plc s7-314 and cp343 Can you help me.... i cant turned it on by magic packet. Do you have example project or tutorial? ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 12/17/2020 08:11:48New subject after splitting |
12/19/2020 5:14 PM | |
Joined: 9/27/2006 Last visit: 6/17/2024 Posts: 12260 Rating: (2671) |
Hello Mohamad; Ali_Nikandish95 was searching for a solution to the same problem, and proposes a tutorial explaining how he has managed it: "Wake on LAN" with a S7-317-2PN/DP, using Step 7 Professional:TIA Portal, and a UDP broadcast. https://support.industry.siemens.com/tf//ww/en/posts/turn-on-a-pc-with-cpu-wake-on-lan-wol/245602 You might be able to adjust his blocks so that they work with your configuration. If not, please come back with the error messages you face and screenshots from your application. We may be able to help you understand why. Hope this helps, Daniel Chartier |
