4/25/2007 12:27 PM | |
Posts: 10 Rating:
Hi. I would like to connect two TD 200 units to one CPU, with each TD 200 displaying same messages. Will it be possible? Regards |
4/25/2007 1:47 PM | |
Posts: 10 Rating:
What about values which I need to input from TD to CPU? It will not be a conflict if I change value in first TD and after that change in second TD? Regards |
4/25/2007 2:49 PM | |
Posts: 10 Rating:
Last question , which cable I need to connect 2 TD´s to cpu. Thank You for answer! Regards |
4/27/2007 8:40 AM | |
Posts: 10 Rating:
Thank You once again. Regards |
