7/20/2007 10:15 AM | |
Joined: 1/22/2006 Last visit: 10/8/2020 Posts: 73 Rating:
Dear Experts, The parameter you supplied is defined in the symbol table assigned to your resource. The data type entered in the symbol does not match your formal parameter. Check your symbol table and change the data type for the symbol if necessary. You can also change the interface of the called block after you delete the call. This action affects all users of the called block and leads to an expanded display. AttachmentTRMTD.zip (454 Downloads) |
7/20/2007 2:10 PM | |
Posts: 29 Rating:
Dear Sevab - Peter |
