3/4/2013 11:52 AM | |
Posts: 1530 Rating:
Hello Avant, please take a look at this FAQ: What should you watch out for when running SIMATIC WinCC or SIMATIC PCS 7 with Microsoft SQL Server 2005 on PCs with multi-core or multiple processors? Best regards Bizur |
3/26/2013 11:52 AM | |
Posts: 139 Rating:
Hi Bizur |
6/3/2018 6:19 PM |
Joined: 3/14/2010 Last visit: 9/4/2024 Posts: 359 Rating:
SPACE PLACE |
Last edited by: Alex3110 at: 6/4/2018 10:04:44 AMLast edited by: Alex3110 at: 6/9/2018 5:49:40 AM |
6/4/2018 10:00 AM | |
How did you solve the problem ? |
6/5/2018 7:18 AM | |
Any ideas ? |
6/7/2018 7:40 AM | |
6/9/2018 5:48 AM | |
I have exactly the same problem when I try to install WinCC v.7.0 SP3 on my laptop X751L with Windows 7.0 SP1 x64 bit . As I know the WinCC Software uses the restricted version of MS SQL Server called "SQL for WinCC". Is it correctly to follow the link https://support.microsoft.com/en-us/kb/954835 ? I have Intel Core i5-4200 CPU onboard : If I use the link https://support.microsoft.com/en-us/kb/954835 then what should I use exactly : Method 1 or 2 or anything else ? Note pls, I need to install WinCC v.7.0 SP3 exactly cause the same version is on a running Operator Workstation with WinCC CS and WinCC RT (a Single User WinCC Project) |
Last edited by: Alex3110 at: 6/14/2018 7:19:09 AMLast edited by: The Helping Hand at: 6/14/2018 12:36:19 PMNew subject after splitting Last edited by: Jen_Moderator at: 6/18/2018 2:51:01 PMMoved posts back and deleted splitting remark. |
