8/22/2023 3:53 PM | |
Joined: 5/30/2022 Last visit: 8/5/2024 Posts: 558 Rating:
Hi yasmben, Possible causes for a panel to freeze are: 1- That the physical limits of the panel have been exceeded, I attach a link for you to review: 2- If there is a file in the compilation that has not been compiled correctly/is corrupt/damaged, I recommend that you delete the IM folder, recompile Software and Hardware and load the project again: How do you delete the IM folder of your TIA project? NOTE: For the IM folder, if you can update the software to the latest available update beforehand, it would be the most optimal.
If this information really helps, you could use the Rate function. |
8/23/2023 12:58 PM | |
Joined: 6/29/2023 Last visit: 8/27/2023 Posts: 9 Rating:
Thank you veryyy muuuch. |
8/25/2023 2:37 PM | |
I'll let you know once done |
