10/3/2017 9:18 PM | |
Joined: 9/2/2013 Last visit: 11/6/2020 Posts: 48 Rating: (19) |
Hi, Node-Red isn't installed in the standard folders. Can you test this: If the IOT2000 has internet access WIFI or LAN) On console type : npm -g install node-red-dasboard Else: Download dashboard from GitHub: https://github.com/node-red/node-red-dashboard Unzip to a folder. Open WinSCP program. Select folder. /usr/lib/node_modules/node-red-dashboard Make a backup from folder (by copy) to a safe place. Copy files from Github and replace all files. Restart IOT2000 and check if dashboard runs in Node-Red. I am not sure if its works. In worst case you can restore the dashboard folder or create a new SD card OS. Can you us tell the result ? Good luck. |
Last edited by: Ocean_ at: 10/3/2017 9:22:33 PMLast edited by: Ocean_ at: 10/3/2017 9:43:34 PM |
10/3/2017 10:03 PM | |
Posts: 2 Rating: (0) |
Yes it works! Thank you |
