10/16/2014 7:21 AM | |
Joined: 3/14/2008 Last visit: 5/14/2024 Posts: 2066 Rating: (928) |
Also watch out that you don't use driver blocks with diagnostics together from classic library and new APL. The compiler seems to have trouble with it, that you can't use diagnostics blocks from two libraries together.. |
10/21/2014 10:50 PM | |
Posts: 2661 Rating: (279)
After copying the new block to the offline block folder you need to import it to the chart folder... |
