5/4/2007 4:33 PM | |
Joined: 10/11/2006 Last visit: 7/12/2024 Posts: 5874 Rating:
Hello, yes, your thoughts are correct, if you want to access e. g. the fault codes in p945, then you can use the formula DB945.DBW(1024*(drive object number) + index) for that. Attached are the two relevant pages from the commissioning manual regarding Simatic HMI addressing. Regards, TechTeam AttachmentHMI.pdf (913 Downloads) |
With best regards, |
