3/22/2017 2:49 PM | |
Joined: 4/28/2015 Last visit: 6/3/2024 Posts: 3345 Rating:
Hi, you have to choose the Intel Galileo Gen2 as board. In the Arduino IDE go to Tools > Boards Manager and search for Intel i586 boards and install them. Did you install the COM drivers? The right way how to do so is described here: https://support.industry.siemens.com/tf/ww/en/posts/usb-driver-iot2020/158539/?page=0&pageSize=10 Best regards! |
Last edited by: bergmanu at: 3/22/2017 3:00:45 PMattached screenshot Not working for IOT2050 support anymore from March 1st, 2024. |
3/23/2017 9:34 AM | |
Posts: 71 Rating:
Have you flashed the SD card with the example image and is the card installed correctly in the device? |
3/23/2017 12:20 PM | |
Posts: 10 Rating:
I'm working on the SD Card now but no luck yet. I'm using this site: https://software.intel.com/en-us/get-started-galileo-windows-step1 when using Method 1: I downloaded: Intel® Galileo Windows 64-bit Arduino* Installer but in this folder, I can't find a file to install. Method 2: when I go to the download page as described I can't find the file: Galileo Board micro SD Card Linux* Operating System Image. I did have downloaded: Micro SD Card Image for Linux Operating System -> Latest Yocto Poky Image. because I figurerd that is the file I need. but not there is not a .bz2 file in this folder. so I can't extract the .bz2 file as described . what should I do now? thankyou! |
3/23/2017 12:22 PM | |
Posts: 71 Rating:
You need the image for the IOT2000, not for Intel Galileo. Have a look at the official guide: https://support.industry.siemens.com/tf/ww/en/posts/setting-up-the-simatic-iot2000/155642/?page=0&pageSize=10 |
