8/25/2021 2:23 PM | |
Joined: 9/27/2006 Last visit: 6/7/2024 Posts: 12260 Rating: (2670) |
Hello Abdelari; S5 for Windows is an excellent alternative for Siemens' Step 5, but I hope you understand that for support on non-Siemens products you should ask the vendor's support team and documents. https://www.ibhsoftec.com/DL-S57W-Eng If you open the S5 for Windows Getting started manual you find in the link, you will see that once you are online with your PLC, yoi can "Transfer to PC" thr files you found on the S5 PLC, and save them as a .S5W file. Hooe this helps, Daniel Chartier |
Last edited by: dchartier at: 08/25/2021 15:07:54Last edited by: dchartier at: 08/25/2021 15:08:07 |
8/25/2021 3:51 PM | |
Posts: 11 Rating: (0) |
What tool is used to connect the pc with the S5-95U to upload the s5 program? |
8/25/2021 5:32 PM | |
Hello Abdelbari; What exactly are you asking? The tool is S5 for Windows (or S5/S7 for Windows). To connect between the S5 for Windows PC and the S5 PLC, you require a TTY connection (current loop cable), such as this USB-S5 adapter (also from IBH Softec): https://www.ibhsoftec.com/IBH-USB-S5-Adapter-Eng Hope this helps, |
