1/25/2024 11:10 AM | |
Joined: 10/18/2017 Last visit: 7/22/2024 Posts: 23 Rating:
good morning, is there a possibility to disable/enable the USB port of the Comfort panel via a script? thanks Valter |
1/25/2024 2:00 PM | |
Joined: 8/3/2009 Last visit: 7/24/2024 Posts: 13359 Rating:
Hello Valter_pv Check out Option+ https://support.industry.siemens.com/cs/de/en/view/109754400 Or you can also use a USB Lock for security: https://support.industry.siemens.com/cs/de/en/view/109481300 Bye Murof |
