9/8/2014 12:18 PM | |
Posts: 17 Rating:
Okay.. then i should use the DB with disabled "Optimized Block Access" Before i can enter it likea pointer? |
9/8/2014 1:24 PM | |
Posts: 17 Rating:
Okay, the UDT can contain almost same structure as a Struct - but can an UDT be accessed with an index number? Then my problem is solved... :) |
9/8/2014 1:29 PM | |
Posts: 17 Rating:
Okay, then it could be a solution... Is it also possible to set UDT as a input to a FB - like a struct? |
