2/23/2015 10:05 AM | |
Joined: 11/29/2011 Last visit: 7/17/2024 Posts: 1358 Rating: (232) |
Hi, An example of using DPRD_DAT:SINAMICS G/S: Configuration of standard telegrams in TIA Portal |
- What you read here, please check with manuals and your requirements. |
2/23/2015 12:26 PM | |
Hi, I did not find sfc14 example in SCL but I found an other SFC example posted for "UBLKMOV". It suggest:
In your case It should be something like this: Try this and let us known if it worked or not. If TIA supports this system function I do not see why it would not work in SCL. Anyways the best way to find out is to try it! PS: What is interesting, how to build ANY pointer in SCL see it here https://support.industry.siemens.com/tf/us/en/posts/112502/. |
Last edited by: MicroMan at: 2/23/2015 12:32:46 PM- What you read here, please check with manuals and your requirements. |
