5/23/2023 2:19 PM | |
Joined: 5/6/2022 Last visit: 7/16/2024 Posts: 431 Rating:
Hi AutoGen_3961284, The information I found says that it is not possible to use KP8F with a non-failsafe CPU in TIA Portal. Therefore, there is a KP8 variant. KP32F, on the other hand, works, where you can remove the F-DI module in the configuration. Also, you can still make it work with another GSDML file: https://support.industry.siemens.com/cs/ae/en/view/50710644 -> You can opt out of security on "shared devices" and that's how it works. I could try to see. If I remember correctly, I think you were considering changing this behavior with TIA Portal V18. Although I have not been able to verify if this is currently possible in 18. I hope this information can help you. Best regards! |
Last edited by: Jen_Moderator at: 05/24/2023 07:54:18Link optimized. If this Information really helps, you could use the Rate function |
5/24/2023 6:03 AM | |
Joined: 2/12/2021 Last visit: 6/1/2023 Posts: 5 Rating:
Hi ElonksuM_SN_BN, First of all, thanks for your response! |
