9/15/2008 6:43 AM | |
Joined: 9/27/2006 Last visit: 4/28/2024 Posts: 12257 Rating: (2665) |
Hello Pandiani; Here is some information I found in the A&D Mall. Follow this link and click on the Description tab: https://mall.automation.siemens.com/GB/guest/index.asp?aktPrim=0&nodeID=10020348&mlfb=6DL3100%2D8AC03&aktTab=4&lang=en It does state it is available for PCS 7 v. 6 and v.7. It would be worth investigating the PCS 7 Portal to find manuals. Hoep this helps, Daniel Chartier Edit: Just to add to the preceding information: the PCS 7 Portal does not give direct access to the AddFEM manuals; it states that they can be obtained on a CD you can request from Siemens. There is a request form you can fill there. Too bad, it looks like a very interesting module. Regards, Daniel Chartier |
