5/23/2017 6:12 AM | |
Joined: 9/20/2014 Last visit: 2/7/2023 Posts: 56 Rating: (20) |
Hello I have user error in FM458 after MMC change , i checked USF Function Block I do not Understand KW1,2,3,4 Means , Please help me How can I solve this problem .. Thanks ------------------------------------------------------------------------------------------ |
Last edited by: The Helping Hand at: 5/23/2017 9:34:56 AMNew subject after splitting |
3/14/2018 12:37 PM | |
Hi I was very busy in this time , Thank you for your Response. This Function have a Library that I Attached for you ,I had to put the original memory card back on the FM458 How can I Find or Generate Memory Card Keyword ? best regards AttachmentFM.pdf (615 Downloads) |
5/4/2018 6:30 AM | |
Posts: 22 Rating: (1) |
Hi , You need Keys - 4 Nos for SWP (Software protection block) to unlock/Run the FM-458 program. This key you will get from Siemens Gmbh or Siemens. You have to provide some details of your HW as mentioned below: 1) MMC card MLFB No. & Serial No. with snap 2) FM-458 module : MLFB No. & Serial No. with Snap 3) Go to online CFC in wich you insert SWP(Software protection) block : Snap. Pls find attached sample file in this file mentioned required information for generate FM -458 key from Siemens . NOTE: IF YOU GET MORE INFORMATION ABOUT FM-458 KEY PLEASE UPDATE. AttachmentFM_Key_Client Name _Project Name.pdf (633 Downloads) |
9/3/2018 11:21 AM | |
Posts: 1 Rating: (0) |
i have the same question ,do you solve it . HELLO ! I HAVE SOLVE IT. |
9/6/2018 6:40 AM | |
Hi no, i can not Solve |
