11/5/2013 9:18 AM | |
Joined: 3/20/2013 Last visit: 4/3/2024 Posts: 676 Rating:
hey dylan, what exactly is the point you have problems with? you parametrised your 1SI modul like advised? Your Tx is at Pin1, Rx is at Pin5, PE at pin 8. You did the cabeling in the right way? You are calling S_SEND and S_RCV with the right parameters? the maximum length of a telegramm is 224 byte, therefore enough to transmit the 93 byte of data you need. please tell us more details of your problem. Best regards, Fafner |
Best Regards, |
11/6/2013 7:03 AM | |
Posts: 29 Rating:
Hi Fafner I should be back in the office shortly and will try it out. Thanks again. |
