10/18/2020 12:45 PM | |
Posts: 5 Rating:
I have "illegal instruction" issues when using "Modbus Read" node. npm version 6.4.1 Welcome to Node-RED =================== 18 Oct 07:00:49 - [info] Node-RED version: v1.1.3 18 Oct 07:00:49 - [info] Node.js version: v8.16.0 18 Oct 07:00:49 - [info] Linux 4.4.185-cip35 ia32 LE 18 Oct 07:01:13 - [info] Loading palette nodes 18 Oct 07:03:16 - [info] Dashboard version 2.23.4 started at /ui 18 Oct 07:03:18 - [info] Settings file : /home/root/.node-red/settings.js 18 Oct 07:03:18 - [info] Context store : 'default' [module=memory] 18 Oct 07:03:18 - [info] User directory : /home/root/.node-red 18 Oct 07:03:18 - [warn] Projects disabled : editorTheme.projects.enabled=false 18 Oct 07:03:18 - [info] Flows file : /home/root/.node-red/flows_iot2000.jso ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 10/19/2020 11:43:06New subject after splitting |
10/20/2020 8:34 AM | |
Posts: 5 Rating:
Sorted out!
Attachmentflow e CT.pdf (201 Downloads) |
Last edited by: Jen_Moderator at: 10/20/2020 09:50:42Edited text for better reading. Last edited by: Jen_Moderator at: 10/20/2020 09:53:44Division of questions into separate topics. |
