5/29/2018 2:31 PM | |
Joined: 9/9/2015 Last visit: 6/11/2024 Posts: 41 Rating:
No Suggestion? I need to finish this job as soon as possible. So please if you have any hint let me know about it Regards |
6/1/2018 8:48 AM | |
Joined: 10/16/2007 Last visit: 6/19/2024 Posts: 627 Rating:
I just switched on my old Notebook and made some screenshots (attached). Sorry this is German Step5 but it should look the same. First you have a special program called PROM525 to program the EPROM. When you start the program and press the F4 you can fill out what EPROMER you have. If you want to program the EPROM you press F1 from the basic screen and select your file (a *.525 file). And remember: if you use a CP525 you also can use a RAM. This is easier to make online changes. For the CP524 you need an EPROM. Regards AttachmentCP525.pdf (275 Downloads) |
6/4/2018 7:47 AM | |
Hello, check attached document about S5EPROM. Regards AttachmentS5EPROM_e.pdf (309 Downloads) |
