11/15/2011 2:42 AM | |
Joined: 10/7/2005 Last visit: 5/12/2024 Posts: 3005 Rating: (1048) |
Hello Tomy Master it seems you haven't allocated V memory for the USS library instructions which would explain your problem. Attached is a screendump from the chapter 11 of the the S7-200 System manual which shows you how to do so and I hope this helps. |
Cheers |
