5/24/2014 6:22 AM |
Posts: 235 Rating:
Dear @anku, Yes if neutarl is not available in your systrm then You can use earth as neutral but there is another better option for you and its a 2ph 380-415V suplly is used for UV release.Yes its available in 3WT ACB.Please find the attached sheet for more details Kind regards Attachment3WT ACB.pdf (707 Downloads) |
5/27/2014 7:28 AM |
Posts: 235 Rating:
HEY jeet2907 Thanx fo responding but i would like to know as i am selecting a LSING breaker will it have any effect on the earth fault protection or any other protection??? Dear @nkur As per your requrement if u have no neutral then i will recomded to use 380-415V UV release,And for more detilas abt to LSING over erth fault without neutral pls follow this LINK. hope this will helpfull to you |
