3/12/2018 3:00 PM | |
Posts: 17 Rating:
Hello, I would like to ask how does comparison between two VARIANT datatype work. Thank you in advance! Best regards, Janko |
3/13/2018 5:25 AM | |
Joined: 3/16/2015 Last visit: 10/10/2021 Posts: 1250 Rating:
You can use VariantGet and then a simple compare function to compare to Variants pointing to a PLC data type. Try the attached archive and see if that works for you. Note the project is using a s7-1500 as the simulator doesn't work well with variants and s7-1200. Edit: That's TIA 14 SP1 update 5 AttachmentVariantCompare.zip (150 Downloads) |
2 thankful Users |
