3/8/2024 1:20 PM | |
Joined: 8/3/2009 Last visit: 6/14/2024 Posts: 13030 Rating: (1660)
Hello AutoGen_3646402 If you use a global script to get access to a screen ressource then you have to use absolute paths. so here is a liitle description how you get access: https://support.industry.siemens.com/cs/ww/en/view/109792585/47189492619 (the same is in WinCC help system) It you do not get it work then write what you have tried so far an how is your screen architecture built Bye Murof |
