6/8/2020 12:56 AM | |
Joined: 9/27/2006 Last visit: 5/20/2024 Posts: 12257 Rating: (2668) |
Hello Ginkoboy; If you look in the WinCC programming reference (TIA Portal), you will see that toupper, tolower, isupper and is lower are functions for C-script, not VBS. https://support.industry.siemens.com/cs/ww/en/view/109755216/36123880331 Hope this helps, |
6/8/2020 3:19 AM | |
Joined: 1/26/2019 Last visit: 9/13/2023 Posts: 69 Rating: (1) |
Daniel, Can I use cscripting in wincc advanced? I am trying to utilize toUpper function . If I can't do cscripting or those function in wincc vbs, what can I do? If I can perform cscripting in wincc advanced, how do I do that? Revise: Here indicate I can utilize the std vbs functions. https://support.industry.siemens.com/cs/mdm/109755216?c=35033065483&lc=en-AR I might try some function from the references. Will keep post updated here. Meanwhile, if anyone has opinion, will be great to hear. Also, does anyone know if we can .net dll in the vbs? I Ifread somewhere about including the com... Etc.. If yes, could someone share a sample? |
