10/9/2007 8:03 AM | |
Joined: 10/11/2006 Last visit: 7/12/2024 Posts: 5874 Rating:
Hello Sreeram, the drivestatus °007 means fault ("Störung" in german). You should check, what is the fault number (r947) and the fault value (r949). Attached you find the list of faults and alarms. If there was a fault before power off, which was not acknowledged, then the fault is presentagain after power on. Attachmentvc34_kompend_s_w_e.pdf (287 Downloads) |
With best regards, |
