12/27/2023 6:33 PM | |
Joined: 9/12/2023 Last visit: 12/27/2023 Posts: 1 Rating:
Hello I purchased a VDF 560 Boehringer Lathe 1998, Serial # 1022.3516-03 I had it installed afew months ago and when powered up, I would get a NCK alarm. I never resolved that at the time and am now taking a look at the problem again. But when I turn on the machine the Monitor will not power up It shows there is power to it, but the control screen does not show. It is a replaced monitor on machine, and a message of (monitor going to sleep) show up in text so the monitor is functioning There is just no Digital readout or instruction to start up Any input would be appreciated ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 12/28/2023 08:28:42New subject after splitting |
12/29/2023 6:03 AM | |
Joined: 10/17/2007 Last visit: 9/11/2024 Posts: 4019 Rating:
Please make sure what is Siemens CNC system you use? --I hope you have all parameter back up If it is 805, you can set service switch to "2" then power up system--But attention You system will be clear reset -all parameters gone please check manual attached
Attachment266_805_SW4_Installation_Instructions.pdf (267 Downloads) |
