10/23/2023 4:53 PM | |
Joined: 12/14/2022 Last visit: 7/9/2024 Posts: 63 Rating:
Hi, To use git or other version control tool integrated to you VCI you need to install an AddIn (Non Siemens software) and link it when you create your VCI workspace. Here there is an AddIn I did based on another one made by own Siemens, and there is also a good explanation on how to install and use it: IgorCoraine/TIA_Add-In_VCI_Git_Connector: This TIA Add-In allows you to connect your VCI workspace to a Git repository (github.com) If you search for AddIns you might find others, I think the link explanation will help anyway. You can also download the Siemens one I used as base here: TIA Add-Ins - ID: 109773999 - Industry Support Siemens Just keep in mind that you wont get any support for this, once is not an "official" tool. |
igorcoraine.github.io |
3 thankful Users |
3/28/2024 9:29 AM | |
Joined: 6/19/2017 Last visit: 6/28/2024 Posts: 8176 Rating:
New question published by aanse is split to a separate thread with the subject Are S7-GRAPH elements not version-tracked?. Best regards |
