11/3/2014 10:27 AM | |
Joined: 2/21/2014 Last visit: 3/14/2024 Posts: 652 Rating: (344) |
hi mvisconte, If you are talking about tagname in Block icon then: If i remember correct, there is a internal Tag whose value is by default set to 0. You can find the tag in tag management->Internal Tag. I think the tag name is something like "xxShowTag". change the value of this tag to 1. now the Tagname will be displayed by default. I hope it helps. Let me know the results. if this does not work, please attach your block icon. HarrY |
You can always use "Rate" and "To Thank" button to appreciate my efforts in helping you :) |
This contribution was helpful to4 thankful Users |
11/4/2014 10:47 PM | |
Posts: 5 Rating: (0) |
Precisely I had the same problem! Thank you very much for share this! |
1/14/2020 12:09 PM | |
Joined: 10/18/2012 Last visit: 5/23/2024 Posts: 1 Rating: (0) |
ING I had this problem Thanks every one |
